2006 Fiesta Vee 250 Mid-Bilge / forward bilge?
Hello all... I'm 2 month into owning this wonderful boat and have some questions that no one seems able to answer. First is do I have a mid-cabin bilge? I don't mean the sealed unit under the stairs that the cabin sinks and bathroom floor drain into. I mean an actual mid-bilge. I ask because I live outside of Buffalo, NY and am worried about freezing issues. I have seen a dark brown nasty sludgy type water come out of my top right side through drain when running my bilge pump manually but only twice. So this has led me to believe that maybe there is another bilge pump mid-cabin but I am unable to find it or access to it. Rinker has been less then helpful with schemantics, actual manuals or any sort of real information that will help me. 2nd question-- I bent the anchor guide this weekend as it got snagged on something really well. Do they simply unscrew with those 3 big screws or do I need to worry about a backing plate underneath that will fall if I unscrew that to try and fix the bend? Thanks for all the help and please forgive my ignorance or lack of nautical terms as I am new to owning this style or size of boat. Thanks again...
Post edited by DonMont1972 on
Re question 2, ours too at one point had been "adjusted mechanically" and I got it back onto shape by careful use of adjustable wrenches and grips padded by rags or toweling in the jaws. Allows you to bend things back to shape or alignment while securely mounted and not damage the metalwork.
I replaced my shower sump pump even though the old one was working, and I have kept that old pump as a portable ancillary backup. The 12v power cord has a cigarette lighter plug on it for fast deployment if necessary.
Andy
thanks,
