What would cause my 320 fiesta vee to struggle getting on plane
We purchased this summer a 2005 320 fiesta vee with twin 5.0 mercruiser engines. Ran great the first month. Then one day couldn't get over 25mph, and the following day could not get over 13mph. Could not get on plane at all.our mechanic did a complete tune up on both engines and did find a fuel line leak. He replaced the fuel line. Took boat back out and still no change. could not get on plane at all.he has now blown out the fuel lines and did find some gas in them . Took boat back out today on a flat lake, was able to get on plane but it was a struggle. Never got over 24 mph... any ideas
Are you getting any unusual beep alarms when you start the engines? Beyond that, I'm running out of suggestions.
both engines able to hit rpm ?
how old is the fuel
or recent fill
up.
gas tank air vents checked?
if props are clean, couplers are good and compression is good start looking at ignition and fuel
As you are moving and water flows over the propeller of the weak engine it may effectively partially assist in powering this motor and the engine RPM may match the good engine, even though the weak engine is totally gutless.
