No spark but engines cranking. Need help
DazeOff
Member Posts: 164 ✭✭✭
Went to start the engine this AM and it started with no problem. Ran for about 10 seconds, sputtered and shut off. Restarted for a few seconds and that was it. I thought maybe my fuel gauge was a little off and I ran out of fuel. Put in a few gallons, tried starting and there was nothing. I have a carburated, mercruiser 5.7 350. Checked the carb and it was pumping fuel into the chamber when the throttle was pumped so I know it was getting fuel. I checked to see if I was getting a spark but there was nothing. Looks like I'm not getting anything out of the ignition coil which is what I'm hoping is the problem. The question I have is this. Even if the coil is bad, should't it register on a volt meter when I turn the ignition on and touch the positive side of the coil terminal? If it should show 12 volts (not showing anything now) even if the coil is bad, what else could be blocking the juice? Any troubleshooting tips would be recommended.
Thx in advance
Thx in advance
try hooking a jumper wire from the positive side of battery to the positive term on the coil, and then check for spark
good luck
You may not be energizing your coil, which relies on the ignition module when it is passed through from the helm (key switch) bridging the juice.
That little 90a fuse block that is attached to your starter is also suspect... the stud that holds it on should also hold the starter cable-to-battery and is your engines main power source... the little block feeds ALL your harness power... engine will turn with it being blown but there won't be power otherwise to the engine. You CAN bypass it by placing the harness wires under the main cable, but i wouldn't rec running it like that constantly.
