What are you guys using for oil on your 5.7's
DanD2
Member Posts: 848 ✭✭✭
How many hrs on your boat?
What Brand Oil?
Synthetic or Mineral?
Viscosity?
Volvo / Merc?
What Brand Oil?
Viscosity?
Volvo / Merc?
Have to return the fuel filter they gave me though. Need the cool fuel one.
Years past I've been using Mobil 1 0w-30 and my oil pressure has always been low. One motor would idle around 35, the other 25ish. At cruise, both were around 40. I decided to go to Quaker 15w-50 this time and my oil pressure is higher. Idle is 40 on one and 35 on the other. Cruise is 60 - 50 respectfully. I'm happy with that. Oh by the way, I've got around 650 hrs on my motors and the oil still looks very clean.
My 350 MAG MPI's only take 4 wts w/filter. Anything more overfills.
5w-40 and 25w-40 are the same weight. 40 weight. the W implies the weight in winter service on start-up and is a compound oil. at one time compounds were considered inferior to straight oils, and due to the fact they sheared to whatever weight the base oil was (not 40, but depending on the derivative/class of oil used in the base such as dino in a group 1-3, or ether found exclusively in a group 5).
DanD2 said: bearing clearances. if you're being told to run 50w it's a good idea to do so. the shear weight of the oil comes into play, and it's importance can't be ignored. shear is described in this case as the ability to cling to hard parts- the gap in the bearing cap is designed to hold a certain amount of oil to provide 'padding' to the moving parts. in a perfect world, the metal never touches but instead rides on that skin of oil... if you run lighter oil or an oil without the ability to cling (shear) to the metals, you're going to wear parts much quicker.
also, the weight comes into play while considering the type of hydraulic lifter used... lighter oils prefer lifters with tiny ports, so it doesn't drain down too fast if at all on a resting engine. some lifters designed for heavier oils will have a bow tie shaped port that exchanges oil quickly when the engine runs, but doesn't bleed down too fast when the engine stops (preparing/protecting for restart).
there is a lot that goes into oils. the easiest way out is to use what's recommended.
.....and the more often an oil is heated to hot performance levels the more likely it is to shift to its lowest base viscosity.
.....as 212 states use the oil recommended for your application.
