Can't set VitroFrigo fridge to "Off"
When we got the boat this spring the temp control knob on the VitroFrigo fridge was seized. Some persistent back and forth finally freed it up enough that I can crank it up and down, but still can't seem to get the last click to off. So only way I can shut down and defrost is to turn the batteries to off. Tried to get the plastic knob off so I could get pliers on it to crank harder, but doesn't seem to want to come off. Maybe some kind of contact cleaner or lubricant sprayed around the control?
Try some WD40. Worked on mine. My frigs are wired direct to the batteries. If you have a fuse on the DC panel that says fridge, then yours is wired to the batteries and it doesn't matter if you turn off the main DC switch.
Hope that's not a common thing for the Vitrifrigo units. I just upgraded to one this season and have been very happy with it.
Yeah, if you can't get it to work with some WD40, I'd say just put a switch on the live line. Not sure if you can change the breaker to something that you can pop yourself, as I can't imagine you need to defrost often.
Pulled the batteries today to wnterize so good for the winter.
