Is the deck layout on a 2006 342FV the same as the 2004 model?
canaancanaan Member Posts: 22 ✭✭
The reason I ask is I'm looking to put in Seadek on my 2006 342FV.  Seadek has a 2004 template from another boater.  Measuring everything they look identical.  Was just wondering if anybody knew definitively if the layout is the same between the 2004 & 2006?  I've attached the layout the Seadek sent me on the 2004 model year.
  • rmfridayrmfriday Member Posts: 104 ✭✭
    pieces 13,14,&15 are dependent on what swim platform you have. I have a 2005 with the dingy package so i don't have the fender holders on the back of my boat and the swim deck is different. The rest of the pieces should be the same
    right, your swim platform is different than the 2004. Everything else "should" be the same. Templating your swim platform is super easy, I did it last fall in about 15 min.
