Engine Hatch
I have looked through past posts and learned a lot about the engine hatch and how to activate it when you have removed your batteries. Unfortunately, I am one of the few who cannot get his hatch to go down using the emergency posts near the transom. It will go up with no problem using my jump start battery, but not down. My questions are:
1. If I connect to shore power and turn on my charger without the negative terminals on my batteries connected, will my charger blow up?
2. Will my charger supply 12v power to my house loads, specifically the engine hatch without the negative terminals on my batteries connected?
3. Is there some other work around?
Thank you.
Thank you.
I struggled with mine as well @Kordo.
Reversing the polarity did not work with mine as everyone likes to say is the solution. There are some type of a diode or something on back side of those terminal studs; I think mine (and yours) are bad in a way that we only have up.
My solution ended up being tapping in 2 wires directly to the hatch motor wires on the transom, then feeding the wires out rear where the scupper is at hatch. Then I hooked to my battery. Then the reverse polarity will work for you. I intend either removing or doing a more professional job in the spring, but got this to work in the pinch of time I was in.
Make sure you use fairly heavy wire like 8 or 10 gauge; it gets kinda warm through the complete up or down cycle!
Good luck!
Another alternative is to close the hatch, then open it by hand to remove the batteries. (Remove table base, reach into engine room through the hole, disconnect pin at top of actuator.)
I see it as a good opportunity to clean, di-electric grease and re-tighten connections every spring.
