New TPPL batteries plus Blue Sea Systems charger and battery monitor
As part of a major tech refresh on my 2007 Rinker 370, I recently upgraded my house battery bank to TPPL (thin plate pure lead) batteries with a new charger and battery monitor. It was hard work, and not cheap, but I'm happy with the results.
The reason for this upgrade is that I spend a lot of time anchored, including frequent overnight trips, so house battery life is a big deal for me. The benefits of TPPL batteries (long life, faster recharge, no maintenance) are discussed in detail here:
http://rinkerboats.vanillaforums.com/discussion/4526/thin-plate-agm-batteries-vs-flooded-deep-cycle-batteries
My 10-year-old battery charger was designed for lead-acid batteries, so I knew I'd have to change it. I also wanted a battery monitor so I'd know when to crank up the generator, and when to shut it down. Here's what I got:
Batteries: Northstar group 31 TPPL
Charger: Blue Sea Systems 7522
Monitor: Blue Sea Systems 7517
Warning: Do not attempt a job like this unless you are physically fit, and you don't mind several hours of exhausting physical labor. Almost every step of the installation required lots of contortions, hard work and pain. These jobs are never as easy as they seem! For installing the charger itself, start early in the morning, because you won't have air conditioning or other electrical conveniences until you finish.
It was a weekend project, and the Difficulty Level is 3 (meaning, 3 days of taking ibuprofin for sore muscles).
The pain started with installing the batteries. A group 31 weighs 15 pounds more than a lead-acid battery. In tight spaces, you can't lift them the same way that you would lift other batteries. As you can see from the photo, I have to move mine over the top of the water heater into a remote corner with no headroom. Aside from that, it's not complicated.
Removing the old charger - more pain. On my boat, it's on the starboard side tucked away above the water tank. It took me almost an hour just to remove the four mounting screws.
Mounting the new charger - more pain. This step took me almost four hours. The AC power input wires were too short, so I had to splice in another six inches of wire with new connectors. The new charger is bigger than the old one, and it's a tight fit that makes access difficult. Fortunately, the plywood mounting panel that is glassed into the hull was big enough (just barely). But it's tough to reach the hole locations to pre-drill the screw holes, and the charger is heavy and awkward.
Mounting the battery monitor in the helm: Easy, because I already had a spot for it. Cut a rectangular hole, and install with four screws. Took 30 minutes.
Wiring the monitor: more pain. The monitor has to be connected to each battery and the charger. I used 16-gauge 3-conductor for the three batteries, plus a 16-gauge ground. There's also a CAT-5 network cable that goes to the charger. I put all four cables into flexible corrugated cable conduit, and ran it to the engine room (25 feet worked for me). In the ER, I built a custom harness going to the three batteries with inline fuses on each one. The whole exercise took me five hours (including the trip to the store for cable, fuses and other supplies).
Here's what the monitor does: When the charger is on, the monitor shows a charger summary with battery voltage, charger current, and phase of the charging cycle (bulk, absorption, pre-float, float). When the charger is off and I'm running on battery power, it shows the voltage and approximate charge remaining for each battery.
Now I'm going to go take an Advil.
Post edited by LaRea on
[EDIT: Having now used it for a full year, I can say there's no need for a brightness control. Screen visibility is good in all conditions, including direct sun, and it does not interfere with my night vision.]
Overall, I'm very happy with it. The info it displays is exactly what I wanted.
The charger gave me some odd fault alarms after I accidentally left the shore power off and drained the house battery bank down to zero volts. When I reconnected power, the charger threw a "short circuit or reverse polarity" alarm, and it refused to charge the house bank. It charged the starter batteries, but not the house. To use the boat for an overnighter, I temporarily rewired the house circuit to one of the starter batteries. When I switched it back, the charger operated normally.
Battery monitor: I really like knowing exactly what the charger is doing. Having the display mounted at the helm worked out great. I can read it easily in direct sunlight, and it's not too bright for night driving.
I like the idea of knowing what is going on as well. The more information you have, the better. I might look into the same system myself. Just need to find a few boat bucks... VesselView is going to be my next investment.
I'm deciding if I want to just replace the batteries on my 270 or also replace the charging system. Right now I have two batteries connected to a switch. Everything operates of either or both batteries. No separate battery for the started and for the house.
I'm considering going with 2 in one bank and 1 in the other. Using the 2 bank most of the time with the single for emergency use.
Although ... your boat is a 2001? If the charger is original, it's probably not going to last much longer.
http://rinkerboats.vanillaforums.com/discussion/comment/87934#Comment_87934
Thanks @LaRea
It was labeled "house." Maybe the original owner reconfigured the batteries, and didn't remove the original cable. I always knew there was a stray cable, but today I finally traced it out and yanked that sucker out of there. One less confuser in the engine room.
BTW I love the charger monitor. When I first start the genny after a day at anchor, the charger is pushing 30+ amps. After a while, I can watch it start tapering off to 20, 15 ... when it gets below 10, the batteries are pretty close to full.
