Bravo III Regular maintenance
onislandtime
Member Posts: 309 ✭✭✭
Is there a reason to separate the drive for regular maintenance? Pulling drives off to sandblast and anti foul painting. Greasing the prop shafts. Anything else except the gimble bearing and bellows to check?
@reneechris14, you don't have to replace the plastic guide shims every year but I check them. I had one half broken off one year and one partially worn through another year. Aren't expensive and just pop on and off.
