swim platform removal, dash addition, carpet
removed old swim platform in preparation for install of new one.
installed a Lawrance HDS-7, removed the old HDS-5 and replaced it with a panel housing an outside air temp, clock and a manual trim indicator for the outdrive. Not connected yet, but soon.
had a couple carpet pieces made for the steps
Sure it could be done, but no need, the tach is still visible from the driver seat, just looks that way fro the camera angle.
TECNOGRAFIC, INC.
1010 NW 51st Place
Ft Lauderdale, FL 33309
www.tecnografic.com
They made all the panels except the center dash that houses the speedo, tach, etc., that I bought a new one from Great Lakes Skipper, shipped it to them to finish to match the other panels. They also did a radio panel and the last panel for the trim indicator and temp and clock panel.
They do a great job but not cheap in price.
The Price is Right
MacRay Harbor, Harrison Twp., MI
As far as I know, TECNOGRAFIC, INC. does not 'wrap' in vinyl, they actually coat the material. They are not the only ones who 'coat' material, there is a shop near me that does powder coating and they also do coating. They have a vat that is filled with a liquid, I assume water, they add the coating to that liquid and slowly dip the material in it and it comes out with the pattern you select. Do a google search about coating, maybe a youtube video to see how it is done. After they dip it, they clear coat it.
The downside of using factory panels is they are plastic and crack easily, the Tecno stuff is much better.
Now we have to have that repaired prior to bottom paint.
Since this was my first time having a bottom blasted I failed to cover the trim tabs and outdrive so some of the paint was removed from the drive and the tabs are no longer shiny. Oh well lessons learned.
Also a pic of the new panel for the mechanical drive indicator, clock and outside temp. Not connected yet, a spring to do job.
