Winterizing a Horizon (fresh water cooled) engine..
 J3ff
                    Member Posts: 4,170 ✭✭✭✭✭
J3ff
                    I've had mostly smaller simpler boats. I'd usually just hook the boat up on muffs, let it heat up and then run 5or so gallons of rv antifreeze through it, to the point where the pink stuff was coming out of the exhaust for a minute or so and then after it all cooled off I'd pull the drainplugs for the risers and that would be that.
Now I've got a 383 FWC full closed loop system. I'm assuming it's the same process-right? Should be even easier as there's less regular water in the engine to get rid of..and with a FWC don't have to worry about heating it up enough to get the thermostat to open - right?
So as far as the water goes, it sound be just a simple flush with fresh water from the hose to get rid of the salt and then run 5 or so gallons of antifreeze through it and done? yes?
I've googled it, but can't find anyone talking specifically about a mercruiser FWC engine, and def no 383 posts.
(I'm aware of the other needs, fogging, stabil, etc..) this post is just concerned with getting the regular water out of the heat exchanger/rest of the plumbing..
if storage will be for longer then let’s say a year I would spray some fog oil into cylinders instead of the intake anyway.
If you have closed cooling all you have to do is drain your exhaust, coolers, raw pump and cats if you have them.
no need to drain the block since you have freeze in it
If you have sea water pickups that go through the hull make sure you close those off BEFORE you fire up engines when running on the hose. Otherwise it will just run out there and can starve the water pump and burn it out.
It's 1.88 at walmart for this stuff.. wasting a few gallons isn't a big deal.
