Can surge brakes be converted to electric on trailer? If so, anyone do it?
 04FV270riverrat
                    Member Posts: 268 ✭✭✭
04FV270riverrat
                    Has anyone converted their trailer from surge to regular electric brakes? My 270 has surge brakes on the trailer. They seem to work fine, just every time I stop and take off I can feel the plunger going in and out and then kinda jerks as it catches once I take off. My truck has the built in brake controller so I figured I might as well use it.
I'm looking at the etrailer EoH kit, specifically: https://www.etrailer.com/Brake-Actuator/Hydrastar/HBA16-252-82.html
You'll need a third axle kit if you have a triple (I do): https://www.etrailer.com/Accessories-and-Parts/Redline/9579-01.html
You'll also need an electronic brake controller that's compatible. My tow vehicle came with a Prodigy P2 wired in (but I just discovered my reverse isn't wired into the hitch - WTH?).
You'll also need a solid coupler, or to drill/bolt your current coupler. I'm thinking my nice coupler, in like new condition, is worth at lease the price of a solid coupler on the used market, so I'll buy a new solid coupler and sell mine when I'm done.
Labor is fairly straight forward - if you know how to bleed brakes you should be able to set up and calibrate your new system. Otherwise find a local trailer shop, it should be under $1500 for parts and labor.
properly adjusted and working surge brakes work good.
hydraulic or electric means nothing if you don’t have the weight and brakes to stop the load.
i see mid size suvs pulling large boats and trust me under emergency conditions that truck will be pushed like a toy even with electric brakes and anchor out the side.
I got a 2500HD rated for 12k, tows my 270 just fine right now. I just hate the jerk every stop and takeoff from the surge brake cylinder going in and out in the hitch.
