Moving generator in a 320
I am new to this forum. Boat in the Canadian Great Lakes and have been following and enjoying this forum. Sounds like a great bunch of Rinker owners. I have a 2005 320 that has a list to the starboard side. This list is not as aggressive if my waste tank is empty and my water tank is full (starboard for waste, port for fresh water). My generator is located in the middle of the boat ahead of the engines. I was wondering if I could move the generator to the port side to try to offset this list . It looks like fuel and electrical lines have lots of room to do this and I can move the batteries easy enough. The only problem that I see is that I would have to lengthen the gen exhaust discharge hose and was wondering if extending this hose to run from port all the way to the starboard side might effect the discharge. Any thoughts on this would be appreciated. Thanks
best way to level your boat is to Move batteries to the high side.
i did that on my sea ray. That boat had everything on the star side which caused a good list which I solved by putting 2 batteries from Star to port.
I suggest temporarily moving the batteries from stbd to port so you can see if that's enough to level the boat. If it works, then do a permanent move.
It would be a good opportunity to clean up your battery wiring too. Most boats after 12 years have accumulated at least some accessories that are direct-wired to the batteries without proper fuse blocks.
If you relocate the generator, it's 200 pounds moving 4 feet. If you relocate the batteries, it's 80 pounds moving 10 feet. Should have the same effect.
http://www.nuclead.com/leadballast.html
