Rinker 330 (Merc 5.7 EFI , Fresh Water Cooled) - How to Flush Cooling System
Hi. Am new here and just got a Rinker 330 powered by twin Merc 5.7 EFI engines driving Bravo3 outdrives. The engines are fresh water cooled.
I did a search and could not find anything (although I wouldn't put it past me to have missed some of the threads here) , apologies if this has been discussed before.
I was told by the former owner that the engines could be flushed with fresh water with a hose after use and pointed out a hose (or a pair of hoses) beside each engine which (as far as I can see) leads to a valve.
1. Is there any literature out there about how this flushing is to be done ? If none , is there some information here ?
2. I understand that the flush would push out the raw sea water from the heat exchanger and the manifolds/risers and was worried that I may inadvertently fill up the Y exhaust pipes with fresh water and then drown my engine. Is this possible if the flush is done without a running the engine ?
3. From the diagram of the Bravo3 outdrive , there isn't a water pump in there ? Would that mean that the raw sea water cooling of the engines relies entirely on the raw-water pump driven by belt at the engines which feeds from a thru-hole in the hull ?
Thanks in advance.
Thanks in advance.
A 1/2 inch hose can only carry 3.5 gals per min,from what I've read the pump pumps 7 gals per min at idle, so I feel that you could starve the pump.this is just my opinion.
Thanks. If the raw water thru Hull valve is closed and a garden hose is at attached for flushing wouldn't the raw sea water pump also draw seawater from the outdrive during the flushing?
There is a sea water pump, as well as water circulating pump.
One more thought: Don't forget to flush!
https://www.perfprotech.com/blog/wp-content/uploads/2014/02/fwc-flow-diagram-copy.jpg
