Shore power
taylor1
Member Posts: 46 ✭✭
Im not sure what this breaker is called on my 400ec. It’s on the aft port side. If I run the vacuum cleaner, the line two will trip after about 1 minute. Also, it trips with the ac on intermittently. If using the genny, this has never happened.
Not sure if this is a dock power stand issue, power cord issue or a breaker issue. Any advice would be greatly appreciated, thanks guys
So the first thing, like Handy said, is take that switch panel off and inspect the wiring at the back. Look for signs of heat damage, and find out if it's an ELCI.
If i need to replace the breaker, would there be an upgrade/ better breaker to consider?
Thanks!
This got me thinking about bringing my boat up to the current ABYC standard by installing ELCI breakers. From what I've seen so far, they are not cheap.
Not sure why this would be moved to the cabin. I was told it was at the back of the boat for a last minute shore power off before getting off the boat from an electrical fire or issue.
I'm curious what it looks like behind your breaker. Make sure to take some pictures, as I have identical boat. I'm guessing you may have to pull out small fridge.
Here's a video by ABYC:
