Rinker 180 Bowrider
glennfam2003
Member Posts: 7 ✭
I have a 2000 Rinker Bowrider with the 3.0L engine. The engine is shot but it was gutless anyway. Is it possible to replace it with a bigger engine? Anyone ever done this?
Would it be possible to replace mine with the 4.3L engine???
I bought a new 1994 Rinker 190 with a 4.3 LX in it which I swapped out with a 350 Magnum which I later had stroked to a 390 HP 383. So, yes it is certainly possible if you can fit it in and IMO your 180 hull should be fine with a 4.3 in it. It would, as @skennelly stated, be a rocket! Keep us posted as you investigate! Good luck!
Now to find a motor to replace the 3.0. Any suggestions?
