Backing down boat ramp and winch cable Snapped!!!
2youngns1stBowrider
Member Posts: 3 ✭
So last summer our first full summer with our 91 Rinker bowrider,just the two of us,I'm in the back in boat while he's in the truck easily backing down the boat ramp ,all of a sudden I hear a very odd noise! A loud snap, all of a sudden the boat is hauling A$%,down the ramp into the water before I could even think, I run to the back of the boat seeing if our motor was going to hit. Then realizing this just might flip love!!!! Thank heavens it didn't!! No cracked hull! Thank goodness! The only big problem was our new propellers one.blade was bent and scraped up. Just wondering has this ever happy to anyone else??.. I was so Scaired but luckily we all came home ok that day! The hardest things was trying to get boat back on trailer without a winch cable!!! Just thought I'd share my experience. Waiting on summer to give it a go agina!!! Finger crossed we will be successful!!! Oh k forgot to mention that was our 1st time out by ourselves . Since we are fairly new to boating!!! Come on summer ready to put our 91 Rinker bowrider 4.3 v-6 in board in the water!!
2youngns 1st bowrider
i would winch and secure safety during haulout as well.
habbit regardless if it’s a bunk or roller
@zaverin1 has a good suggestion with the safety chain. Might be time for a new winch if you haven't replaced it already. I think they use the flat straps now.
your story isn't that bad.
a word of advice, if i may:
it's a very good practice to put some slack in the winch cable/strap before you back down. on dry skids a boat sticks pretty well- when wet, it slides like it's on bearings. or, should. but that isn't my advice that may or may not carry weight, this is- ALWAYS tie a line to the front cleat that's no longer than the length of the boat- and tie the other end to the trailer tower. you're boat isn't getting away from you this way. the captain of that boat is also the driver of the launch vehicle until the mantle is passed- and that is the deliberate handing off of that tie-line. driver get's out, inspects their work, unties the line and hands it to the captain, or ties it off to the landing while they clear the ramp of the truck/trailer.
i watch guys with more confidence than sense do this: they'll tie off as i suggest but with a line as long as thirty feet and instead of the trailer, the dock... they unstrap the winch, back carefully down the ramp and wet the skids- pull up carefully out of the water for fifteen or twenty feet or so, then drop into reverse and goose it, stomping the brakes when appropriate- boat slides off with force and floats back to the end of the line where it 'snaps to'.... don't get me wrong, i appreciate these guys as they more often clear the ramp ahead of me far faster than careful folks like me, but..... why take the risk?
the other thing fun to watch are all the 'power loaders' who line up on the trailer on pick up, and lay into the throttle. i watched a fella just last summer snap a parking sprag in his trucks transmission doing this, and had to hold the truck in place with the power of the boat until someone jumped in the truck and set the parking brake. that was so full of fail it could be discussed for several more paragraphs.
so your situation isn't that uncommon. from here out, though, tie that thing off with a bow line, huh?
