Which bank does lighter socket run from?
Realizing I can find out by trying the battery switch but that's at least a month away. I want to get one of those volt meters that plugs into the dash socket. But is that reading starter bank or house bank? Was there a specific set up? 2000 Ri nker FV270.
Or did you replace your socket all together and put the meter in the hole and wired both feeds to the meter? The type I'm talking about just plugs into the socket, doesn't replace it, so only reads whatever source is feeding the socket.
Edit: rereading your post, it seems it's fed on both sides? Or direct and not through the switch?
You will have 3 lugs on the back of the switch...battery 1 positive lead, battery 2 positive lead and output lead from switch to the engine...your meter positive wire would hood to this. Negative still goes to negative.
If that's not how he's doing it....you could certainly do it that way to achieve what you are looking for.
I remember doing this with a previous boat I had trying to figure out what was hooked to which battery (or both).
