Lost reverse on starboard
buggyjdav
Member Posts: 134 ✭✭
2004 FV 342 with twin Merc 350 Horizon engines and Bravo I/O's. Need some advice. At end of last season while docking I lost forward in my starboard engine, reverse works fine. Checked cables all the way to the engine and they are working fine. It's something in the Bravo drive, maybe cable broke? Any thoughts?
Based on what I read...if you can shift into forward and nuetral but not reverse it's most likely not the cable and something in the shift linkage in the drive or worse gears
When replacing, make sure your cable is routed correctly, or it will rub.
The other issue is the brass portion of the cable where it goes through the bell housing. On mine the nut that is part of the housing seperated from the housing. When shifting into reverse, you are pulling the cable, and when this broke it allowed the cable housing to pull through bell housing instead of the cable pulling the drive into reverse.
This is another reason that slower is better when docking, if the cable fails, damage will be minimal.
