Running wires for a/c control
I’m currently replacing the stock a/c unit that came with our 342 with the marinaire unit that several others here have recommended. I’ve got the old unit out and am trying to figure out how to get the wires for the control panel and remote sensor run up to the place where the control panel is mounted. This seems like the hardest part of the whole deal. Any advice from others that have done this before?
The factory units came wired with Cat5e with an 8P8C (commonly mistaken to be an RJ-45, but you can typically use those two connector names interchangable - no worry). The wire was terminated as a crossover cable. The cable that came with my new unit was also a Cat5e, but wired as a standard patch cable.
So, reusing the old cable is likely as simple as reterminating one end.
The new unit is SO much quieter. You will appreciate it!
If that's the case, I do need to run the remote sensor or the unit will always run based on the readings in the locker.
I wonder if they've updated the design since others here have installed.
I have the MarinAire unit, which has two thermometers: one by the inlet and one at the remote panel (not the remote control). It'll run until both those thermometers are satisfied, not just the return air one.
