Battery procedure
I just purchased a 2008 28 ft ec and I am not sure how I should use the two batteries. Should I have both on when cruising, or just one and which one. When plugged into shore power, should both be turned off? When anchored which battery should I have one on and the other one off and which one?
I hear so many different answers. Can someone explain to me how it all works please.
Welcome to the forum!!
I leave my battery switch on all the time, except when laying up for the winter. It's just easier that way. If you have the 280EC, there is a wiring diagram available for you to download here on the forum. If you want it, I can direct you in the right direction.
the basis is:
both on: max available battery reserve. more importantly, both are charging while you're cruising.
one off (one isolated): only using half of your reserve (if you've got two batteries only), and only one charging while you're cruising.
you'll want to isolate (turn off a battery i.e. flip to only one) if you're moored and engine or generator is not running. this leaves one battery (your starting battery) isolated and presumably fully charged as you deplete your 'house' battery. when your about to start the engine, pull anchor and head back- you flip the switch to the starting battery or both. this ensures you have power to get started and home.
And the "Generator" switch simply turns On and Off the dedicated Generator battery?
The generator switch turns the starting battery on/off to the generator. That's it.
The left switch should be set to ON unless one battery has failed or is missing (not common). The right switch provides battery power to the generator to start/stop/operate. It'll provide AC power to the distribution panel in the cabin.
There's an isolator that allows the batteries to charge independent of the switch position. It's mounted to the starboard firewall, behind the generator exhaust. Look for the black thingy with a bunch of red wires attached.
When the generator is running and the battery charger is flipped on it'll charge through the same battery isolator.
If you leave the boat without shore power for a period of time you'll have the house battery drain down - there's a MerCathode system and a CO detector that draw about 1/10th of an amp - with a 110AH battery it takes about 22 days before your battery is 50% discharge, and past that point you're damaging the battery. Mine's a trailer sailor: when I leave it for more than a week I disconnect the batteries, top them off with a charger, and lower the hatch with a battery pack. I'm adding solar soon - but probably a dingy first.
