Water under aft mattress - 280 EC
I have a 2007 280 EC, and I've noticed water under the aft mattress, right in the center, against the bulkhead. It doesn't appear to be coming from above or below: both bilges are completely dry after running the boat hard for 4 hours. The water tastes salty to me - I'm pretty sure it's not a freshwater or rainwater leak. And water isn't on the sides as much as the center.
I don't see any water along the freshwater hoses to run to starboard (where they head to the head) and I don't see any water near the water heater at all. The engine compartment is dry everywhere I can get to.
I have the Kohler 5ecd generator, and it appears to have a vacuum breaker installed up above where the greatest concentration of water is, with a (dry) clear hose running out of it.
Any ideas?
Any ideas?
Didn't look wet and salty, but I imagine that's not right.
Anyone ever replace this? Is there an easy way to do it?
good luck
Bazza.
Has to be coming from the genny, more I think of it.
Even if these photos are displaying for you right now, they aren't for us...and I notice it in all of your posts.
Large photos are a bust, especially if on mobile. And links to Google Pics or whatever are always a problem, again, especially on mobile.
And I'm sure a lot of us use our phones for pics, so may I suggest an app called Photo Resizer that works great on my Android, might be an Apple version I'm sure Cuts a pic to small upload size, but keeps them a reasonable size for download.
When installing the new AC unit the hose from the AC output to the thru hull connection, at the thru hull, wasn't sealed all the way. Water would run back down the hose until it contacted a wire bundle, then follow that wire bundle to the firewall. The mid-cabin sole (floor) was installed with the carpet glued down, so it's carpeted under the walls and against the hull. This carpet would wick the water up, and while the wall is solidly resting on most of the floor, the back corner of the wall is cut slightly rounded (likely to facilitate an easy fit when putting it together). This is where the water was coming under the mattress.
The thru hull doesn't have enough room for two hose clamps, but really needs them. The upgraded hose I used is thicker rubber, and doesn't compress enough to properly seal. I swapped out with a piece of the older thinner-walled hose, tighten it up, and no more leak!
