Need Help. Is there a way to improve getting up on plane for the 40 Express Cruiser?
I bought a 2010 40 Express with twin 496 Mag 8 L Bravo 3s with 160 hours on it. It is slow to get up on plane. I don't want it to struggle with more people and weight on board. Can I upgrade the props? To what pitch? Wider trim tabs? Fuel additives? Or is this just a design limitation?
Fuel additives will do nothing.
Engine tune up might help. Esp cap/rotor as they can corrode.
As for the engine rpm: Mercury has a max (wide open throttle) rpm range for your specific engines. Take the boat out on a nice water day, get on plane/trimmed out. Go to 100% throttle. Your rpm’s should be in the Merc specified range. Too low means you are over propped.
Definately start with the tune-up first!
Also look at weight distribution. Even on that big boat, balance matters. For example, do you normally run with a big beer cooler in the transom locker? Try temporarily moving it to the v-berth. If it makes you plane faster, balance might be part of your problem.
On my 370, adding another 40 pounds of chain to the anchor rode made a big difference (because it's so far forward).
