Loud heater/air condition fan - brand new Rinker
I am a new Rinker owner. We just put our brand new 2018 Rinker 270 EX in the water. We stayed over our first night and needed to put the heater on.
What a disappointment !!! It was so loud we could not sleep. It was a toss up between being cold and putting up with the cool temperature. We opted to turn the heater off! There didn't seem to be variations in the fan speeds either.
Our dealer has spoken to a Rinker rep and was told that the fans that are installed in the Rinker are noisier than normal!! Why would Rinker accepted this sub standard fan from the manufacturer to install in their boats? It is no better than the cheapest bathroom fan from 20 years ago! Of course we would not have known this when we bought the boat.
I bought a Rinker because of it's reputation for quality. When it comes to the heater/air conditioner unit, they really dropped the ball if this noisy fan is standard.
I would appreciate any comments and/or advice. Thanks.
Disappointed Rinker owner
Best Answer
raybo3
Administrator Posts: 5,588 admin
I have a 2002 342 and my A/C/Heat is not loud at all. If I were you I would contact Rinker directly and ask them. IMO that should not be loud enough to keep you up. Good luck and keep us posted. Welcome to the forum........2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Like all boat makers, Rinker buys things like engines, water heaters and A/C units from common vendors. Used to be that they put MarineAir A/C units in their boats. Not sure what they use now. But odds are it's the same brand that's used by several boat makers. There isn't normally a "fan" separate from the A/C. The unit should be all one "box"
I don't have it handy, but I'm sure someone here can get you an email contact for folks at Rinker. It would be worth sharing this with them.
The dealer should come look at the unit and make sure there was not something mis-installed, or packing material that they forgot to remove. It could be as simple as something too close to the A/C unit that was supposed to be moved as part of prep.
I have an older (2002) Rinker with the original A/C. It's under the V-berth where we sleep. It makes noise but it's not obnoxious. I could put some sound deadning material on the lid and the cavity it's in but so far it hasn't bothered me enough to take action.
Best of luck. Keep us posted.
Good to hear the dealer is coming out, but I'd still reach out to Rinker and let them know about your disappointment. If nothing else it may help things along if there has to be some work done to correct the problem.
Like others stated, the fan is part of the AC/heat unit. It is an all in one unit. They are made by Dometic and used on boats around the world. You could have a defective unit, or something got bent and the squirrel cage is rubbing the outside of the unit causing the noise. When I purchased my 280EC, I had some noise with my AC unit. Through some troubleshooting on my own since it was a used boat, I found that the grill in front of the AC unit had come loose over the years. I installed some weatherstripping between the grill and the mounting frame and the noise was gone. Since your boat is brand new, the dealer and Rinker should get this addressed. Hopefully it is one minor hiccup. Once resolved, I am sure that you will enjoy your new boat.
Turn on power
I'm assuming you have a Dometic (Marine Air) that looks like this.
