Losing RPM on STB 350MPI Rinker 342
At cruise speed STB engine RPM fluctuates. When at idle or low speed its fine. After stopped for couple hours and restart, gets on plane runs for 10 minutes and same symptoms occur.
If actually the engine is maybe suspect a fuel issue. Filter maybe.
http://www.mercruiserparts.com/
Edit: Don't know if this is your motor or not, but in this page you can clearly see the additional fuel filter:
http://www.mercruiserparts.com/bam/subassembly/31754/15322/60
are there 2 filters inside each module?
