Best Tool to enlarge speaker cut outs
WillhoundWillhound Member Posts: 4,217 ✭✭✭✭✭
Looking to install my new stereo and speakers tomorrow. A test fit and measure shows me that my current cut outs are 5 1/4" and my new speakers require 5 1/2". And I plan on shifting them over a bit to allow for contours, so the cut will be larger on one side. Best tool I can think of that I already own is my Dremel. Cutting bit and do it fast, or grinding bit and do it slow and sure (and more dust). Thoughts? Different tool? I do have a curve cut jig saw. Maybe work better?
  • tk1973tk1973 Member Posts: 122 ✭✭
    edited May 2018
    Do it al’s Way if you can. I used a dremel and a jig saw and remember it was a pain in the a$$ for me. Also remember to wear a mask. The dust was nuts.
    Post edited by raybo3 on
    Jig saw with fine tooth blade
  • Robs_232Robs_232 Member Posts: 212 ✭✭✭
    I've done what Al suggested. It does work very nice and makes the project go way faster and easier. If you don't have the hole saw's, I would bet you can rent a set. Might be $60 to buy.
    You can put a spacer behind the speakers.
    When using the Dremel make sure you go the right way for the tool (cw is ccw). I just put 6 speakers in my 342 yesterday, when with the polk audio DB651 because they fit the hole. Did have to redrill the screw holes.
    Yep I had the same issue, used a reciprocating saw to cut Fiberglass holes larger and a spacer on the arch so i didn’t have to cut the thick aluminum
    Used a Dremel with a spiral bit to enlarge the fiberglass holes in my 280 once.  Worked like a champ.
  • WillhoundWillhound Member Posts: 4,217 ✭✭✭✭✭
    I like Al's idea but I need to "slide" the hole over a bit on two of the cuts or else the new hole will intersect with some of the curves on the combing. Sounds like Dremel or jig saw. Will bring both along with shop vac for dust.
  • Kaptain_KenKaptain_Ken Member Posts: 75 ✭✭
    edited May 2018
    Hi Willhound. I did exactly what you have to do.  I replaced the 6.5” speakers with 8.8”.  I used the JL supplied template to outline the hole. I then cut one side with a rotozip type tool but because I went through several bits, I cut the other side with a jig saw. The jig saw did a better job.  Hope the pics help.
    Wow! If I had to go that big I'd likely use the jig saw too. Just finished the holes. Just had to trim a bit and the Dremel worked great. Ran the shop vac right beside it and sucked up most of the dust. I love the smell of resin in the morning !
    jig saw FTW
    Are 2006 270 Rinker speakers 6.5''?
    Patrick
    06 Rinker 270
  • JonnyMJonnyM Member Posts: 305 ✭✭✭
    Yes they are.
    Thank you sir
    Patrick
    06 Rinker 270
