Possible someone put wrong geared bravo 3 on?
Ok so quick run down. Now the boat gets on plane, both new engines sound super strong and smooth. Issue is the port engine will not get past 4000 RPM. The throttle can be all the way open and nothing. The starboard motor accelerates right past with ease. With everything I've done to the boat now, motors, props, I honestly think who ever replaced the port drive put a bravo 3 with the wrong gears in it. My boat should be 2.20 I believe. Could the symptom I'm seeing be gear related?
2001 340 Fiesta Vee 20P Hill Marine and 2 new 6.2 Horizon motors. Whine Down
how did it run b4 the prop change
with or with out trim=any difference
Alternatively,you could try travelling at a certain RPM (2000 maybe) using each engine in turn. A lower ratio should give more boat speed per engine revolution.
John & Kathy
2002 FV 310 "pair*a*dox"
also every body buying hill props=would they need to know the gear ratio to properly tune ?
also thepriceisright = was having rpm issues=haven't heard back from him
