towing skiers/tubes
I have a 1988 captiva 206.  My old boat only had the 2 U bolts for hauling and that worked fine with a booster ball.  This boat also an O ring above the swim deck.  Any advice on which to use for both?  thanks
    I've used both or either one, the o ring being in the center pulls better. A heavy **** does not sway the boat. as much. side to side. It's easier to tie onto the O above platform that the U bolts under there.
    Towed a lot of people including slalom skiers who put a ton of on/off loads on the line and the Rinker center waters ports tow eyes never failed. No gel coat spider cracks - nothing.
