yes, i can change it
hi their this is psuedobot
Post edited by karan on
  • Options
    GMSLITHOGMSLITHO Member Posts: 1,560 ✭✭✭✭
    I’m in .... great idea
  • Options
    Great idea.
    2002 - 270FV Mag 350 B3
  • Options
    Liberty44140Liberty44140 Member Posts: 4,332 ✭✭✭✭✭
    Hey Wild, definitely makes sense for me as our boats are under 10 miles from each other. I don’t have hour meters so it would be great to get a snapshot of true hours and compare my oil and temp gauges to reality as well as do an overall check. Would be of value to me to rent at some point.
  • Options
    The software has a few tricks up it's sleeves too.
    We can monitor each year the output of the raw water pump and stay ahead of it wearing out.
    Fuel Injector Test
    Code Checks
    See Faulty Sensors
    Spark Fire Test
    Idle Speed Test
    Injector Kill Test
    Actual Engine Hours
    See Max RPMS and how long engines have ran at each level of rpms
    And a lot more in addition to all of our ECM data and Graphs.
  • Options
    vyborny1vyborny1 Member Posts: 77 ✭✭
    Count me in, like @Liberty44140, I could swim over!!
    2002 342 Fiesta Vee
  • Options
    @Wildboating I'm lucky enough to have a friend close by with one.  But you could make a few bucks programming people's port motors when they want to add vessel view.  It seems all the ECMs are set to starboard.  When I did my VV install my friend was kind enough to change the setting on my port ECM.
