Complete stereo rebuild on a Rinker 370
LaRea
Member, Moderator Posts: 7,554 mod
This thread documents a major upgrade to the entertainment system on my 2007 Rinker 370. I’ve been working on it for over a year, and it’s more than just a stereo install. I actually relocated the stereo electronics from the cabin to the cockpit, reclaiming some valuable cabinet storage space in a prime location.
Fair warning: this is a long multi-part post. I like to write, and the writing helped me design the system (not to mention keeping me occupied while not boating).
For those who don't feel like reading the entire build, here's what I installed:
* Cockpit speakers - six Wet Sounds REVO-6 drivers and a REVO-10 subwoofer
* Cockpit amplifier - Wet Sounds HTX-6
* Clarion CMS4 black box media player and two remotes
* All new speaker wiring in cockpit
* All new LED cockpit lighting with Wet Sounds LED controller
* 32” cockpit TV
Why: The Admiral and I are music lovers. We want clean sound at normal volumes, and sometimes we want clean sound at chest-thumping, dance-floor volumes. When my crappy Sony speakers crumbled to dust after a couple seasons (link), I decided to get better speakers. The project didn't escalate into a total makeover until I decided to relocate the amplifiers. Then I just went crazy with it. No February would be complete without me tearing up my boat for some sort of major project!
This speaker was responsible for the entire project.
Before and after ...
[edit: I use Bluetooth to stream music from my phone, so there's a side benefit: I get great reception anywhere on the boat because the receiver is now in the cockpit rather than way up near the bow.]
In this photo, the location is behind and below the blue pillow.
(Edit: To improve transmit range, I got an antenna cable and mounted the antenna up in the top of the hardtop. It's a 3-meter TNC male to TNC female cable like this: https://www.amazon.com/gp/product/B077Y74GCR)
The second photo here is looking down through the trash can opening.
First photo: the 125-A fuse holder bolts directly to the terminal of the house battery bank. A short anywhere in the cable will pop this fuse.
Switches: Power is controlled by two of the existing helm switches. The "cockpit lights" switch turns on the LEDs for the entire cockpit, and the "swim lights" switch turns on the stereo. (I need a new switch cover that says “stereo”.)
Speakers: I went with six Wet Sounds REVO-6 with the white classic grills, and a Wet Sounds REVO-10 free-air subwoofer. I started researching them based on comments from @wildboating and others here on the Rinker forum, and I'm happy with both the sound and the build quality. For example, they have waterproof quick-disconnects for power and LED. The sub is massive compared to the OEM Clarion. It fits into the original 9" opening, but it requires a 3/4" spacer. I re-used the original spacer by cutting the hole slightly bigger with a power jigsaw.
The controller is the key. The RF remote lets me pick any color (including white) and set the brightness. There's a color wheel, and you just drag your finger to the color you want. It will also do music-triggered pulsing, and other flashy stuff that I probably won't use. When I turn off the lights using the helm switch, they go back to the same setting next time.
Edit: the 18/4 wire is here: (LINK). It's $19 for a 50-foot roll, and it has correct color coding. I suppose I could have used smaller wire, but 18 is easier to work with.
Need to know whether your soldering iron is hot enough? Just touch it lightly to your arm. If it makes your arm look like this, you're ready to solder!
(I didn't finish mounting the one in the cockpit yet, so it's just sitting on the shelf.)
This photo shows the view looking down into the rear of the cabinet. The amp is partially underneath the HVAC duct.
The digital output from the TV is routed to the stereo’s aux input by way of a digital-to-analog converter. The TV requires AC power, but I’m going to install a small inverter so I can use it without shore power or generator.
How much: Please don't make me add up how much I spent. Even before buying the speakers, amps, media player, lighting and TV, I probably laid out $300 just on wire and circuit protection. I paid retail prices for everything ... you can do the math if you want. Don’t tell me the answer.
Bottom line: After a 12-month “tech refresh” project, our boat now has the entertainment system we've always wanted. It sounds amazing at low volume, and equally amazing at nightclub volume. I expect it will provide many years of service.
Hopefully this write-up will help others who want to upgrade their boats!
when I did my 280 i did the same thing
ran everything from scratch
not to mention mid 90 boats didn’t come
preowired or wired with amps
One question, that FM transmitter, where do you have the antenna for it? I remember when we did Pau Hana's, we ran an antenna across the inside of the hardtop. I can attest it worked across a raft-up of 24 boats!
But as Pau Hana pointed out, the whip antenna is omni-directional, so it won't reach as far port-to-starboard as his directional antenna.
Curious if you left the little antenna on the back of the transmitter or mounted something external. A 1/4 wave ground plane antenna for 100MHz would be around 30 inches long. It would increase your range quite a bit.
