2014 RINKER 360
JOESONKO
Member Posts: 18 ✭
THE BOAT NOT ABLE TO PLANE, AND MAX RPM CAN ONLY GOES TO 3500, THE BOAT IS SUPER SLOW AND BURN A LOT OF GAS, SPOKE TO MECHANIC AT MERCURY AND THEY CLAIMED THIS IS A COMMOM ISSUE WITH THIS BOAT FROM RINKER, I FOUND IT NOT ACCEPTABLE
Obviously there's a problem let's see if we can help. 2014 360 do you have 496's or small blocks? Do you work on the boat your self? Did this problem just surface? When was the last time the filters where changed and a tune up done? Trim on drives works correctly? Trim tabs work correctly?
When we got our 25' Maxum (first boat) we did not bottom paint it, so by mid-season it would start to drag and by the end of the season we would barely get 10mph out of her. We now bottom paint ;-)
Check the easy stuff first.
Are you dealing with a Merc dealer, or a Rinker dealer? Who, and where?
