2005 Rinker 342 Drain under cockpit bench seat - Port Side
randy9000
Member Posts: 15 ✭
Hello,
Does anyone know where the drain is under the port side bench seat in the cockpit? Also, where does it drain to and how does one clean that drain?
Thanks!
Thanks!
2005 Rinker 342 - Maryland
I did a a 3 inch vent to that compartment so any moisture that found its way in had a way out.
How do you get water out of that compartment? I have standing water in there. When I climbed on to take a closer look I noticed a small hole in the back corner but the water is not draining. Also, where would that water go to?
Thanks,
9000
does that mean water will eventually collect in the Aft Cabin bilge? Will this eventually damage the gas tank if water is leaking on it?
Thanks
it is a small hole. 1/4” at most. Rear corner.
Water ‘should’ go to the mid bilge. Basically drips on the fuel tank top.
