1998 Rinker 192 Fuel Sending Unit access location...
m1xmstr
Member Posts: 5 ✭
Recently purchased a very well maintained 98 Rinker 192. Very happy with the build quality, and ride of this boat.
The gas gauge was broke when I bought it and I would like to change out the sending unit, but have not found exactly where it is...
I assume it's under the rear seat (not a walk through transom)... Is the rear plastic bin (under the seat) just 2 screws to remove?
Or is this located more in the middle of the boat? I do not have snap out carpet.
Thanks for the help,
Matt
Matt
Remove Bimini Top and light look straight down. Can see the fuel lines and sender.
Unscrew the bench seat and access cover from inside the seat.
Squeeze my fat a$$ in the back seat bucket...
Can feel the sender bolts, and multiple wires (odd as I swear there are 4 wires 3 of which are hooked up.
Not ready to tinker with this just yet as it was starting to rain.
Figured out how to get to this unit, and/or how to winterize this Fall.
The following was performed:
(1) - Remove both storage bins from the bilge (4 screws - 2 in each bin)
(2) - Remove both side carpeted wood pieces from back of bench seat (in bilge 2 screws)
(3) - Remove 8 screws from bottom of bench seat (Inside of bench)
(4) - Tilt bench seat forward
(5) - Easily can reach fuel sending unit and wiring...
#profit
*One important side note!!!
There are screws below the cup holders in the bench seat, I ripped the side skirt vinyl by pulling the seat to far forward... Not sure how the cup holders come out, but warning to others who might attempt this...
