Coax for antenna/cable TV 280 express cruiser
warrantyvoider
Member Posts: 38 ✭✭
Hi, all.
I'm hoping to get pointed in the right direction with a small issue I'm having with a "new to us" 2009 280EC. Our beast has no arch, and no external cable TV hookups that I'm able to find. I'm hoping to install a cable TV inlet, and possibly an antenna.
Inside the cabinet that houses the TV, amp, stereo, etc (on the starboard side), There are seven coax lines, some hooked to a 4-way splitter, and some simply dangling: They are marked -Port, Starboard, Arch, Main (this one goes directly to the TV), Aft, and 2 marked with Antenna. All of these coax cables seem to be bundled together. They disappear through a hole in the cabinet and all head fore of the cabinet for as far as I can see them.
I guess my question is: Where the **** do these things run/terminate? Since none of them run DIRECTLY aft from the cabinet, I can assume that the "Arch" and "Aft" cables loop around and make their way into the cockpit somehow......
If I can't locate the other end of any of these cables, they're pretty much useless to me, and I'll have to run brand new coax. I'm just hoping that somebody smarter than me can shed some light.
Thanks!
Thanks!
Are you telling me that there are cable inputs INSIDE my shore power inlets?
I'll have to double check that.
As far as the antenna goes.....I'm not totally sure yet. An antenna isn't the priority that cable TV is, but I was hoping to leverage one of the extra coax lines somehow (if I'm able to locate where exactly they go).
I'm adding a cable inlet on my starboard side. The port side hookup goes to the old TV cabinet and I have not been able to pull it back. The existing one is on the "wrong" side anyway.
I wish my 342 had dual power/coax inlets. I have considered adding coax, but not sure if 2nd power inlets are worth it.
What I REALLY need is my pump-out on the starboard side so I can use the dockside pump out in my dock. But that's not going to happen.
FWIW, I was unable to locate the arch line. I looked to both Port and Starboard where the arch would be. No dice. No big deal, though.
if you’re able to share pictures of your connections, that would be very appreciated.
I connected “arch” to the inlet on the Shakespeare amplifier, and set it to DC. From the Shakespeare outlet, I’ve run a coax into one of the “out” ports on the splitter. I also connected port, starboard to two more “out” ports on the splitter.
Ryan
Anyway, sounds simple but that Shakespeare amplifier is powered. Are you getting 12 v power to it? The other thing to check is the connection up at the antenna. A lot of them use a short cable from antenna to top side of mount and then a connection on the bottom side of the mount for the cable running towards the cabin. Done like that so there's nowhere for water to get into the arch. Should be able to see the bottom of the mount through one of the access plates on underside of the arch.
If that is the case, I’ll try purchasing a new antenna.
I’m thinking the antenna may be broken. It’s strange it won’t pick up any signal, and I’m on southern Simcoe.
I did try this yesterday, and still no luck. It has to be the reception on the lake, or my location on it.
Cheers!
It was on sale for $140 USD.
I'll let you know if it picks up anything!
