Tools to keep at the boat/marina
cmelt2003cmelt2003 Member Posts: 72 ✭✭
What tools and parts would everyone suggest to keep on hand? I’m getting tired of lugging my tools to the boat from home, so I am thinking about putting a box together from Habor Freight. What tools can you not live without?
  • rasburyrasbury Member Posts: 8,874 ✭✭✭✭✭
    everything you can think of and you will still be missing what you need.
  • cmelt2003cmelt2003 Member Posts: 72 ✭✭
    Very true indeed!
  • raybo3raybo3 Administrator Posts: 5,592 admin
    There is a big thread on the forum about this. Just do a search. IMO one of the most important things is a multi-meter.
    I actually did search but nothing came up. I’ll look again and if I find it, I’ll delete this one.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,877 mod
    I keep a socket/ratchet/wrench set of all the sizes along with screwdriver and all the bits.  Channel locks, pliers (couple types), impact driver (with bits) & drill (but I don't use drill that much).  That tends to cover about 90% of what I would need.  I can usually find something around my dock neighbors as well (we all have pretty good tool selections of various things).  Was funny, yesterday my dock neighbor need a cutting tool (hacksaw or sawzaw) to cut a zinc in half that goes into his genny).  I had just taken mine home a couple weeks ago.
    I am up to 4 tool boxes on board. lol. A nice Kobalt socket set in a hard case. 2 plastic tool boxes for screwdrivers, wrenches, multi-meter, assorted zip ties, clamps, fasteners, sealants... Then a small drawer type for electric connection parts. They all get used. lol. And I still end up bringing tools from home!
    edited May 2019
    Well, now I know who to go see when I need something!
  • aero3113aero3113 Member Posts: 9,684 ✭✭✭✭✭
    A filter wrench or filter pliers will come in handy if you have to change a fuel filter out on the water.
  • LaReaLaRea Member, Moderator Posts: 8,016 mod
    A good cordless drill.  I have a Ryobi with a spare battery and charger.  I also have two important accessories that use the same battery.  One is their excellent inflator/deflator ... the fastest way to inflate fenders and water toys.  Also I have a fan.
    The thing about the inflator is that it lets me keep a couple of 24" ball fenders on the boat.  I store them flat, and inflate when needed.  They are great for raft-ups.
  • IanIan Member Posts: 3,029 ✭✭✭✭
    I have a combination of what @Dream_Inn and @Black_Diamond have. Add to that a couple of rolls of rescue tape, electrical tape, heat-shrink and crimp connectors (and tool). As @raybo3 said a multimeter is a must but learn how to use it, there are some key things to know to get the best use out of it.
    I keep a set on the boat that stay on the boat.  I also keep a volt-ohm meter on the boat.  I have debated on getting a compact drill-driver to leave in the boat too.
    Yes, I do keep a multimeter and filter wrenches as well!  As far as inflator, I have a vacuum that connect to a 5 gal bucket.  Works fantastic (& quick) for blowing and deflating water toys.  @LaRea, I bet I can inflate my 36" ball fender quicker than you can your 24" !  :)  (I'm pretty sure I can't, you can only put so much thru that dang needle thing!  That's why I don't carry it often)
    @cmelt2003 dont delete this thread. Its always good to go over this stuff. Here is the older post about tools
    https://rinkerboats.vanillacommunities.com/discussion/comment/88405#Comment_88405
    Apart from the tools mentioned I also keep a spare serpentine belt, distributor cap and rotor and alternator. To be fair, these are all things I changed as preventative maintenance but the old ones were still ok as spares to potentially get me home. Also have a dozen hose clamps in various sizes, fuses, zip ties, marine epoxy, silicone self sealing plumbing tape and electrical tape and a battery booster pack. Oils and fluids. Couple of flash lights. Last but not least a Sea-Tow membership.
