1992 rinker 235 fiesta vee hull/stinger composition
PickleRick
Member Posts: 4,312 ✭✭✭✭✭
Just got a new(to me) rinker. Fit the need for a fun little boat that gave us more exploring opportunity on the local inland lakes than my sailboat. Too many bridges. The boat seems very solid save for a little soft where the batteries sit port side of the motor.
Is this a wood cored transom and stingers or foam? The wood i have found to be exposed has been solid.
Forgive me if this isnt an express cruiser model.
And yes the Fiesta Vee models are express cruisers.
you should see some boats I come across during the season!
some people buy junk for premium and get upset when I call it junk
I did a good knock knock test on her (owning mostly 70s model sailboats over the years i find lots of rotten balsa core) and found nothing i felt unsafe with other than needing some carb work. A wood core of this vintage that was anything other than a weekend holiday use barn kept boat will have moisture.
I ask because when i was pulling old speedo and transducers from the transom and filling with thickend epoxy i didnt find any wood when i cleaned out the bolt holes.
I should also add im handy with epoxy and plywood, rebuilding stingers is a weeknd job. Now rebuilding the Transom and everything wood cored tied to said stingers, well that's a job for someone else. My favorite way to lay a stinger is pour arjay into a mold for the engine mount pad then epoxy averything into place around it with plywood. Im not a fan of something as substantial and heavy as a motor being held jnto place with wood.
