Need Help guys.....Dual Engine Steering linkage (tie bar)
DanD2DanD2 Member Posts: 848 ✭✭✭
Trying to align my engines, they are toed in a quite bit.....been that way since I bought the boat. In the picture below, is the white rod supposed to spin around the threaded piece with the nut? I can't get it to spin (yes I took the pin out) and don't want to break anything.
    That's above my pay grade...
    Anybody?????
  • earl1z19earl1z19 Member Posts: 374 ✭✭✭
    The 2 outer pieces are called heim Joints. They are both threaded. 1 clockwise thread and 1 counter clockwise threads just like a tie rod on your car. Back off the locking nuts and spin the white tube to get your desired alignment. Be careful not to wind them out too far . You want several threads in the white tube on each side. Tighten down the locking nuts when you are done. I dont know how the alignment is to be set but the function of the tie bar is simple
    That's what I thought but I can't spin the white tube, I even used a pipe wrench and it won't budge.
    That may explain why it is toed in now. Someone may have booger-ed up the treads the last time they messed with it. You may need to pop the whole assembly off and adjust it on a bench or at least see why it is not adjustable
  • aero3113aero3113 Member Posts: 9,722 ✭✭✭✭✭
    Maybe try some penetrating oil on the threads?
    I did...I let it soak for 2 days to no avail.
    Heat?
    Heat?
    On the bench that is.
    Also could the treads be bottomed out in the tube?
    Yeah, heat will be my next try but at this point, I think I'll wait until it goes back on the hard. Boat is being put in the water this Friday and the weather between now and then is crappy so I won't be able to get in there.
    It won't turn either way.
