It looks like you're new here. Sign in or register to get started.
icoultha said: Ryobi have a couple of inflaters/pumps that run off their One+ 18V battery range.
Dude_Himself said: Get a low/hi pressure SUP or dinghy pump - it's worth the difference. You won't have a good time with the battery powered big box store pumps. I recommend https://www.seaeagle.com/Accessories/pumps/bravo-bp12-single-stage-high-pressure-electric-pump?AID=531689&PID=7021976&SID=BP12+pump&cjevent=246e8f59821d11e983ef05c60a240614
reneechris14 said: I use a small shop vac $40 blow up the dink then suck out the bilge. Poor thing gets a work out.
cmelt2003 said: reneechris14 said: I use a small shop vac $40 blow up the dink then suck out the bilge. Poor thing gets a work out. You just blow the dinghy up to feel then? Mine has pretty specific psi it wants it to be at.
https://www.lowes.com/pd/DEWALT-12-Volt-110-Volt-Lithium-Ion-Air-Inflator-Power-Source-Battery-Car-Electric/1000632717
Same here. Mine is just one of those cheap ones that fit on a 5 gallon bucket. Also use to blow up all the inflatables.
