Fresh water pump won’t shut off
Spyderweb
Member Posts: 963 ✭✭✭
launched boat today. Drove it 8 miles to home marina and began by setting up the water. Got all the taps running clean water, normal pressure, and stopped spitting air. But when all faucets were off, the pump continued to run. The strainer on the pump shows a little bit of air at the top of it. Don’t know if that’s normal. I find no water leaks anywhere. From experience I know with small leaks pump shuts off but will cycle back on every so often depending on size of leak. For pump to not shut off at all, it would have to be a big, noticeable leak. Any suggestions why pump won’t shut off?
Paul
2008 Rinker 330
Paul
2008 Rinker 330
i do wonder, if pump won't shut off, wouldn’t pressure really build up, and you’d have tremendous pressure in system? Is there some kind of relief valve, like on the water heater?
Anyway, I give up. Will order pump this weekend. Appears straight forward to install. Only concern is if inlet and outlet fittings will be the same. This one has the blue lever you pull and it releases the fitting.
Just a theory.
I think the rebuild kits runs about $35.
Pump will build up pressure to a point (called the dead head) and then it won't be able to pump against the pressure anymore, so flow stops. Pump just then spins without moving water. The real issue is the water in the pump casing gets hot because it isn't going anywhere, and it could get hot to the pump where it generates steam ... and that's when you'll have a problem.
Yes, I have a friend whose 270 caught on fire because his broker left the water pump on. Boat was basically sold, but paperwork was being done next day. Talk about bad timing for him!
Will it it keeps running if it’s sucking air? If there’s a leak downstream of pump it should leak water. I’m thinking if it’s upstream it would suck air but not sure if that would prevent it from shutting off. The pre-filter that attaches right to the pump seems pretty loose. You can swivel it around even when clamped in by the pump. There doesn’t seem to be any gasket on the pump. Should there be one on the filter end?
@DanD2 have not found any leaks. And based on above test, leaks or not, looks like it would keep on pumping.
