Engine oil
caik01
Posts: 39 ✭
I left for a few day trip and prior to leaving checked my engine oil and all was good. After running for 30 minutes I lost my Port motor and checked the oil again and both motors were dry. I have no oil in my bilge. What's the issue?
Both engines?
Weird.
Being both there is either treachery or opposite-of-smart-and-from-behind-just-below-belt going on. Filters on engines? Seated? If remote filter, lines intact? No low oil warning? Even thunderbolt ignitions pay homage to low oil pressure sensor and kill engines when it drops. Something mighty strange going on, pard.
I'd say you're losing oil to exhaust. A poorly seated piston ring can consume a lot of oil. With my first engine, there was a problem with a ring and I'd lose a quart of oil in about 3 hours of operation at cruise speed.
Not sure how long you ran for, or how big the leak could be, but you could easily lose a lot of oil if a ring isn't seated. I had NO signs of oil loss, no smoke, no slick ... it only seemed to happen when I was cruising.
