2002 fv 270 discharge ports on side of boat
cristykcristyk Member Posts: 29 ✭
i believe I need to prime my AC because I am not getting any water discharge when it is running but I do feel the pump trying to pump. (i did clean the strainer) I wanted to push water through the line from the outside but I do not know what port is correct.  Does anyone have a diagram explaining what each port leads to?
  • skuter99skuter99 Member Posts: 174 ✭✭
    What model boat?
  • cristykcristyk Member Posts: 29 ✭
    2002 fv 270
    If my memory is right it's the port closest to the water line and towards the Stern...one above it is the aft bilge discharge
    2002 - 270FV Mag 350 B3
    On my 04 there is a cluster of 4 discharge holes and the AC is the lower aft hole of the 4 on the starboard side
    edited July 2019
    On mine there are 4 on the starboard side the one that has a plastic ring is the one for the ac I think the other three with the stainless rings are sink bilge and shower sump
    Thank you all so much!   I have the water flowing now but ac is still warm. 🙁
    Is the AC unit running? Might have a freon leak.  Hard to troubleshoot yourself
    I have it off now. It was running. I am guessing a Freon leak. We will be getting our oil changed in a couple of weeks and will add that to the list.
