Engine Hatch Actuator 2000 Fiesta Vee 270
Good afternoon.
I recently purchased a used 2000 Fiesta Vee 270. I operate the boat out of St. Petersburg Florida. Unfortunately the engine hatch actuator is completely worn-out and needs replacement. Could you kindly tell me the necessary minimum and maximum stroke required so I can source a replacement ? If you have any suggestions as to make or model ,that would also be very much appreciated. Thank you in advance. Best regards, John
Hey, Welcome aboard. We boat out of Sarasota and get up to St Pete/Gulfport quite often. Send me a PM if you'd like to touch base.
Mike
www.warnerlinear.com
You can usually figure out from the part number the basics of the actuator, like above:
12 =12v
24= 24"
250 = 250lb-f
there are a lot of options if you bother to look into them: stroke limiting, remotes, manual over-rides, etc.
Hope that helps. Mike
Can anyone send me a picture of the wires that connect from the harness to the actuator , it looks as though I have some wires or connection are missing !
I have only a couple of wire coming fro the actuator but have no idea what or were they connect
