Jabsco 36400 filter sight glass on fresh water pump.
Member Posts: 3,015 ✭✭✭✭
Appears mine has developed a crack so sucking in air and leaking. Searching around I can find new complete units, strainer and o-rings but no glass. Anyone know of a place to find - or have one stashed away after replacing unit/pump?
Where did you find an o-ring kit? Been looking on the interweb no luck. I’ve got the Jabsco 31395.
May just totally replace the filter and pump all together.
My units are 2 separate pieces and once I bypassed filter to test, all was good so that's the only issue. Are you sure it's the filter o-ring?
Yes 2 separate units, have the boat on the driveway this Friday - take a closer look. Need to start limbering up. Have to pretty near do a headstand to diagnose & fix.
https://www.boatid.com/jabsco/par-max-fresh-water-pump-inlet-strainer-mpn-46400-0012.html
I'm just gonna replace it all with new. New Jabsco pump, 2x90* fittings & a new strainer. Not very costly at all.
