Engine drain plugs how many??
I have a 2002 fiesta vee 5 ltr bravo 3 ,how many motor drain plugs are there I've found 2 lower ones on each side and one at the front top
  • rcr05261rcr05261 Posts: 4
    Should be one per exhaust manifold (upper plugs) and one per side on the block (lower plugs). Sometimes they are socket bolts versus the blue plugs which are visually obvious to find due to color.
  • aero3113aero3113 Posts: 9,798 ✭✭✭✭✭
    edited January 2020
    Make sure you stick a pick or stiff wire into the lower drains, they can get pretty clogged up.
