Swim Platform Cleat
aero3113
Member Posts: 9,962 ✭✭✭✭✭
One of my swim platform cleats had a nut come loose. I found the nut and washer on the opposite side of the swim platform. Any ideas on how to reach the cleat and put it back on?? I can just barely touch it with my finger but no way can I get the nut back on. @Alswagg ??
Now that my kid is older he can access places I'm no longer flexible enough to reach comfortably. The old mills in the south preferred child labor as they needed less space and little hands can get into tight
spaces.
I have an old battery powered ratchet. Its about 18 inches long. A dab of grease keeps the nut in place on the socket while maneuvering. Gives my 6ft plus wing span plenty of extra reach.
Lightly feather the trigger to be sure you dont cross thread. I always start in reverse then tighten to help align the threads.
A wrench with tape works too. A ratcheting wrench is even better.
Id probably loosen the other nut before installing new to rebed the cleat, dont want any water intrusion.
I wish you luck!
Luckily for me the kiddo is old enough to use the impact driver and the little lady doesn't mind helping when she doesnt have to turn a wrench or scew driver. I hand start the nut from below, hold the wrench and tell her to hit it. The most important part is being sure i have the mounting surfaces clean and sealed properly before hand.
A mechanics best friend. If you turn any wrenches these are a must. I keep sets of these and fixed.
