Ground terminal block
aero3113aero3113 Member Posts: 9,721 ✭✭✭✭✭
I noticed green corrosion on some of the grounds on the terminal block. I removed and cleaned all the terminals and block with some scotch brite, reinstalled then sprayed with some terminal protector. I’m going to pull the battery switch panel also when I get a chance to check all of the connections behind there. Another good item to put on your winter check list!
