Rinker Factory top and enclosures
Stever00
Posts: 145 ✭
Just had couple zippers resewn for my bimini top. Got all the panels to try and zip up all the enclosure for the winter. To my dismay most of the big plastic zippers were coming unzipped as fast as I zipped them. I paid 45 dollars to get two zippers sewn back down. I cannot imagine what it would cost to put all new zippers on Fiesta Vee enclosure. It's crazy how the top was designed anyway. In front where the top zips to the clear plastic and snaps to windshield the top does not even extend forward enough to keep sun off helm. Read where one guy extended his bimini top in front. Also there is no cover over the rear of the boat. I wonder if a bimini top could be made to extend further forward and further back rather than trying to fix a bad designed enclosure. I 'll try post a picture of what it looks like. I believe the tops were originally made by Taylor.
I then mounted the back bow and cut it to where i had a slight rake rearward to help keep the afternoon sun from sneaking onto the bridge from behind.
I don't boat in cold weather so no glass or zippers for me. The only zipper i deal with is the sock for covering the top while storing or towing.
I'm going to build my own rear bimini extension shade. I need 2 aluminum telescoping poles. One will stick into each side of the rear transom in the rod holders.
I will drill/attach rivet held button snaps into the bimini frame to attach one side of sumbrella material and then tie the other off to to the poles. I need sub 3 ft of shade to cover the remaining rear of the boat.
I have thought about buying enough material so i can attach shades to the front/sides/ rear so that we can privately shower on the engine hatch cover while standing without putting on a show for others. Something light, folds down enough to stow under a seat.
We weekend on the boat. Sitting to shower sucks. Going to bed fresh and clean after a day on the water is always a plus.
If my front glass opened i could have lowered the top a bit, would look better lowered about 6- 8 inches but function>fashion i have to be able to step over the glass. If i wasn't so tall i also wouldnt notice less head room. My issue with sailing was i was always hunched over when on board even with 6ft head room and after a weekend on the lake my lower back ached.
One thing you can never have enough of on board is usable space. Towing you're always thinking this is too big. Once on board you're wondering where all the room went.
@Willhound
It is a sweet umbrella. I used a beach umbrella my parents got when i was 5 or 6.
I need to upgrade. After seeing yours I've started looking for a good beer umbrella. Or one that has Goonies on it.
My bimini stays upright in the back supported bow and goes into a storage sock. Takes 5 min to pull out or stow.
Ive never seen a camper top fold down that easily, too many sections to deal with. There are marinas and close proximity to the lake storage facilities around here that cater to trailer storage for that reason. You keep your boat minutes from the lake on the trailer, fully set up. Just hook up an dip.
