Oil in genny
cls10105cls10105 Member Posts: 389 ✭✭
Hey guys been getting all my stuff together for the big tune up. How much does the gennie need for a 2002 342 fv.
cruising on 6. tw0s
    Should be Kohler 5E which is 1.4 Qt of SAE 30
  • PickleRickPickleRick Member Posts: 4,388 ✭✭✭✭✭
    edited December 2019
    Does anyone have any part numbers for service kits or common failure parts/electronics on these?  One of my kohler distributors (RBI) will drop ship direct to any address i request for about 9 bucks shipping.  If i have kohler part numbers i can run them to see if I'm able to get them (im a kohker dealer and authorized service shop).  I may be able to set you guys up with some parts without the marine mark up.
    My Honda certification allows me honda marine look up but i can only order the parts that are also used in outdoor power equipment.  Kohlers site isn't as user friendly to explore.
  • cls10105cls10105 Member Posts: 389 ✭✭
    @Liberty44140 thanks man really appreciate you
    cruising on 6. tw0s
    @PickleRick i have no clue i picked up a tuneup kit from Amazon
    cruising on 6. tw0s
    Impeller is 359978, oil filter is 359771,  Spark Plugs NGK (2) BPR4ES , Fuel Filter: Kohler 267987, Anode: Kohler 260085
    That'd be great if you could share a discount Rick!  I probably have two of everything right now, but I do change plugs, filters & impellers every year!  So it won't take long to go thru them.
    Oh, & drive sleeve is 359448!  Gotta change them once in a while too.
    Unfortunately none of those come up in the kohler system.  The ngk spark plugs do but those can be gotten at any autoparts store.  I keep them on the shelf as Kawasaki and Honda engines run them.
    Here are a few examples of kohler part numbers with a sequence im able to order.  They may structure those part numbers just to keep me and other outdoor power eqipment shops from ordering them.
    I will question my RBI rep when i see him again but sadly none of your part numbers came up in persona where i order them.  My parts counter guy had never seen kohler numbers that short other than old 1980s and older kohler k and magnum series parts.
    What's funny is hondas motorcycles, cars, atvs, outdoor power equipment, generators and marine all use the same part number structure so i can order some of everything so long as it is a part also used in lawn equipment.  Some carbs parts interchange. Parts, seals, gaskets etc
    www.partsfortechs.com
    Don't forget the coupler!
  • aero3113aero3113 Member Posts: 9,964 ✭✭✭✭✭
