Quick disconnect engine block drains
aero3113
Member Posts: 9,684 ✭✭✭✭✭
Last night I Was doing some work on the boat and noticed quick disconnects for the lower engine block drains (2 per block, left and right side). I decided to remove them and check if the drains were blocked, no antifreeze came out. I stuck a straight pick in them and sure enough black muddy water came pouring out then it cleared up to antifreeze (starboard side). I did the same to the port side, they were clogged and antifreeze came out. This will be on my winterization list from now on.
Buddy of mine always says, “how you do anything is how you do everything.”
