01 310 Height on trailer
SeaHare
Member Posts: 193 ✭✭✭
Wondering if anyone would know the approx height of an 01 310 that is sitting on a custom trailer. Thanks (i know it will vary depending on the trailer but looking for ballpark)
01 FV 310, 5.7s carbed, B3s
You could measure up to the trailer fender, allow for compression, then measure a 310 from the chine to the highest fitting to. (see 2nd pic) A 310 with an arch may be a problem as a trailerable boat without using a commercial low-boy trailer. Width restrictions in fl require a simple $20 annual permit for anything over 8'6" and I forget the max beam w/o needing an escort but each state is different.
(EDIT) Our $20 annual permit gets us up to 13'6" max ht, 12' max wd in Fl w/o escort car. Time of day for movement is restricted and I understand the rules are strictly enforced in the Fl Keys. Most 270 owners don't bother but anything bigger probably should. Aside from the fact that an insurance claim may become a mess if you're not properly permitted.
Good luck, Mike
ALLLLLmost fits...
2019 MTX20 Extreme
Yeah that header being a tad low was a disapointment but its an 18" steel Ibeam......so itll take a torch if I find a sweet 320 B-)
Great pics frodo. I am purchasing a similar boat within the next month,and I will be trailering it from Barrie Ontario to Kamloops BC. Would guess it will be about 4000kms. Your Ford tows the 320 with no troubles? I have a 2013 Ram 2500 with the cummins that I am going to use. My main concern was the height,but if you are at 12'11",I think I will be under 13'6" with my trailer. Hopefully we get an early spring!
